I found something which doesn't seem right.
If you create a patch/patcher object, then create any object in that patcher, then parent one of the controls, test the main patch, all works. If you then go back into the patch/patcher and delete the object that was parented, you can't run the main patch, it gives an error.
`C:\Users\MATTH_~1\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancepatcher__1::Init(rootc*)':
C:\Users\MATTH_~1\DOCUME~1\axoloti/build/xpatch.cpp:358:107: error: 'PARAM_INDEX_dial__1_value' is not a member of 'rootc::instancepatcher__1'
parent->PExch[PARAM_INDEX_patcher__1_dial__1].finalvalue = (int32_t)(&(parent->instancepatcher__1_i.PExch[instancepatcher__1::PARAM_INDEX_dial__1_value]));
make: *** [C:\Users\MATTH_~1\DOCUME~1\axoloti/build/xpatch.bin] Error 1
The ways around it are :
- de-parenting before deleting.
- adding back the parented objects you deleted, without parenting them (but you have to remember what they where)
or create a new patch/patcher object and put everything from the broken patch/patcher into the new one.
I'm sure it's just a small bug to iron out, but I had to talk about it, I keep on falling on it.
