Patch not starting on power-up
I'm following the instructions here, for uploading a patch to internal flash...
I can't get the patch to run after powering down and back up. According to the instructions it should start automatically?
In case it was something about my patch (which runs fine in Live mode) I also checked using the tybett demo, and that didn't play either.
Thanks for suggestions!
Try the save as sdcard startup option, this is what I use.
(I'll have to test the flash option, also not sure this work if there is an sdcard loaded , need to check )
Thanks for the suggestion. The tybett example starts fine when running from sdcard. My looping file playback patch still isn't working. Want to check it out to see if I'm doing something wrong?
The patch depends on an initial loadbang to start the file player... perhaps I should put a delay on that to make sure it happens after the patch is fully loaded?
