hi forum,
could someone help me out with a bit of knowledge of how to turn a momentary switch into a toggle switch using the objects available?
im a total newb on this and have much to learn
i have wired six momentary buttons (PB6/7/8/9; PC4/5) as well as twelve potentiometers (PC0/1/2/3; PA0/1/2/3/4/5/6/7).
goal is to use the guitar multifx and control it via the mounted hardware controls.
i want to use for example one button to switch filter modes; one button to switch on/off distortion; one for the reverb and all that. then build (if it is possible) the patch as true stereo. the potentiometers will control the same parameters all the time.
thank you for helping me out in advance.
best,
daniel
