Hello,
I did this patch, to use each pad of the launch controle of novation with an logic counter and different led color for each tree positions.
I was working empirical, so i guess there is miskate, or we can improve it.
The led color, is set with the value.
The speed of the blinking led is set with lfo, i did that because i will use it to know the speed of osc or lfo in my patch. But the true is : i didn't find the right way to keep it alway one.
Anyway, with this patch you have the number and the value of each note, to use the pad launch controle, with the original set up.
Edit this patch " ring buffer overflow the midi send", you should change "usb host port 1" to "usb host port 2 "
axoloti-lauchcontrole-led.axp (22.7 KB)
You can find more information about midi and led for lauch pad control there :
https://global.novationmusic.com/sites/default/files/novation/downloads/6958/launch-control-programmers-reference-guide.pdf
Cheers,
