Parameter dont stay position after demux sh
He there again,
after a demux S_H i used a pot meter sending a midi CC to control the amount of the LFO. My problem is now that when i switch to the next LFO with the the demux object,that the position of the last setted potmeter applies also to the next selected. When i use a normal demux without S_H it goes offcoarse to the 0 point again.
i will embed a picture to make it more clear.
my question is or i can keep the position of the parameter while skipping thru the parameters.maybe it is all because of my potmeters what is leaking a bit and giving a position anyway ?
Hey man :wink: I made a post about a similar issue yesterday. Try @hellcores custom object from the community library called "hookmod". There is a very easy to follow help file included.
Check this thread:
i was just trying this !i just readed your post yes ! no luck yet but i'm sure i will ! thanks!
It is pretty straight forward.... Did you look at the help file? Just click on the little triangle in the upper left corner of the object and choose "help".
yes im looking in it as we speak :slight_smile: but have a hungry 2 year old next to me also haha
it will keep the pot's position untill you reached the hook point ?if i understand correct or am i completly off? still noob :slight_smile:
Ha, I understand. I have 2 kids myself :wink:
Yes it will keep the value you have previously fed into the the hook object, untill you reach that value again. It works with a regular demux, doesnt need the demux sh.
hehe yeah great :smiley:
the example patch is working ,also if i control the button via midi with my potmeter. It do exactly what i want ,this is great! . I just need now a way how to intergrate it in my project . I want to control with one button al the amounts of the LFO (in this case ). the patch was via the midi/intern/cc thin object and a demuxer to make one potmeter, 4 midi CC's, and this midi i assigned to a mixer on every LFO outlet. Im sure is possible and i will find the way :smile:
