Hi all,
I'm looking for help navigating my options for external parameter control via knobs and/or expression pedals. I know to some extent the decisions are driven by how you intend to play/use the Axoloti, but I'd like to understand if there are basic performance differences between different options.
So, specifically, suppose I have some parameter that I want to control/modulate in real time. I could set this up to be controlled by a potentiometer-based expression pedal, by a midi expression pedal, or (per the work @Gavin is doing), a rotary encoder.
What are the key considerations (not on the playability-side, but in terms of intrinsic differences in, e.g. response speed and resolution) that would drive choosing one or another of these?
