hi there
tried installing the app on my new old machine (2nd hand 2012 MacBookPro) running High Sierra.
app will launch and connect, but i can't select any objects and there's nothing in the libraries.
it feels like i'm missing part of the installation.
if anybody knows of a fix, that would be highly appreciated.
i have a newer retina-machine with a broken screen that i can work on for now, but i'm afraid that'll die soon.
(that one's still running Sierra, no issues there.)
this is in the app console window (sorry for long copy-paste):
Axoloti version : 1.0.12-2-0-g7975cc87 build time : 09/04/2018 13:15:31 GMT
Link to firmware CRC E95BAC96
org.eclipse.jgit.errors.RepositoryNotFoundException: repository not found: /Users/Remork/Documents/axoloti/axoloti-contrib
at org.eclipse.jgit.lib.BaseRepositoryBuilder.build(BaseRepositoryBuilder.java:582)
at org.eclipse.jgit.api.Git.open(Git.java:116)
at org.eclipse.jgit.api.Git.open(Git.java:99)
at axoloti.utils.AxoGitLibrary.getGit(AxoGitLibrary.java:232)
at axoloti.utils.AxoGitLibrary.getCurrentBranch(AxoGitLibrary.java:181)
at axoloti.MainFrame$4.run(MainFrame.java:317)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
getCurrentBranch cannot find repo FAILED : community
org.eclipse.jgit.errors.RepositoryNotFoundException: repository not found: /Users/Remork/Documents/axoloti/axoloti-factory
at axoloti.MainFrame$4.run(MainFrame.java:336)
getCurrentBranch cannot find repo FAILED : factory
Status : factory (1.0.12,anon) : local directory missing
at axoloti.utils.AxoGitLibrary.reportStatus(AxoGitLibrary.java:55)
at axoloti.MainFrame$4.run(MainFrame.java:351)
status FAILED cannot find submodule : factory (1.0.12,anon)
Status : home : local directory missing
Status : home : OK
Status : community (1.0.12,anon) : local directory missing
status FAILED cannot find submodule : community (1.0.12,anon)
USB device found
connected
Authentic Axoloti Core
search path : /Users/Remork/Documents/axoloti/axoloti-factory/objects
search path : /Users/Remork/Documents/axoloti/objects
search path : /Users/Remork/Documents/axoloti/axoloti-contrib/objects
finished loading objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
thanks for any input!
