I don't know what to tell, ya, it won't open for me. First time I've had this happen to me. Tried again just now. nothing. It opens a window I can't see or interact with or anything.
@hitachii Yes, I want it to smoothly and slowly warp the sine wave pitch randomly. I tried what you told me to, but it won't let me go live for some reason. I will try some more. I get this:
make: *** [C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.bin] Error 1
Generate code complete
Creating directory on sdcard : /untitled
Done creating directory
Changing working directory on sdcard : /untitled
Start compiling patch
BDIR = C:\Users\Kent\DOCUME~1\axoloti/build
FIRMWARE = .
RM
APP
! C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.h.gch
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancepolySpread__1::Init(rootc*)':
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:135:25: warning: division by zero [-Wdiv-by-zero]
output[i] = ((128<<21) / (1-1)) * i - (64<<21);
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instancewrite__1::dsp(int32_t, int32_t, bool)':
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:191:15: error: 'class rootc' has no member named 'instancetest_i'
parent->instancetest_i.array[USAT(inlet_a,27)>>(27-parent->instancetest_i.LENGTHPOW)]=SSAT(inlet_v,28)>>parent->instancetest_i.GAIN;
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:191:68: error: 'class rootc' has no member named 'instancetest_i'
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:191:123: error: 'class rootc' has no member named 'instancetest_i'
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp: In member function 'void rootc::instanceread__1::dsp(int32_t, int32_t&)':
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:440:35: error: 'class rootc' has no member named 'instancetest_i'
int index = asat>>(27-parent->instancetest_i.LENGTHPOW);
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:441:25: error: 'class rootc' has no member named 'instancetest_i'
int32_t y1 = parent->instancetest_i.array[index]<instancetest_i.GAIN;
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:441:62: error: 'class rootc' has no member named 'instancetest_i'
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:442:25: error: 'class rootc' has no member named 'instancetest_i'
int32_t y2 = parent->instancetest_i.array[(index+1)&parent->instancetest_i.LENGTHMASK]<instancetest_i.GAIN;
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:442:64: error: 'class rootc' has no member named 'instancetest_i'
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:442:100: error: 'class rootc' has no member named 'instancetest_i'
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:443:43: error: 'class rootc' has no member named 'instancetest_i'
int frac = (asat - (index<instancetest_i.LENGTHPOW)))<instancetest_i.LENGTHPOW+3);
C:\Users\Kent\DOCUME~1\axoloti/build/xpatch.cpp:443:81: error: 'class rootc' has no member named 'instancetest_i'
