If you move the patch/file or rename the folder the patch/file is located in, the link from the recent menu will be broken and won't work. Besides those cases I don't remember having any issues.
I haven’t moved or renamed anything... this is puzzling.
‘Open recent’ menu has a list of patches, but when I open a patch that isn’t in the list, it doesn’t get added to the list. But it must have, at some point, because the list definitely has files that I’ve created or opened.
Yes, after a save, it appears in the menu. BUT, after restarting Axoloti, it's not in the menu. Recent files aren't being saved in the recentFiles section of axoloti.prefs (the preferences file.)
I had a file named Patch 3.0. I then saved it as Patch 3.1 and Patch 3.2. I closed opened Axoloti and both were there in the recent menu. So maybe it only saves the recent menu if more than one entry have been done to it?
I agree there is an issue there, but I never noticed it before, to be honest. When I work on a patch i often save many versions, so didn't really notice it. But it is a bit inconsistent.
I don't have a lot of hope that this is something that will be fixed for this version. Maybe version 2.0 will include it if you file it as a bug on Github. But yeah, that version 2, needs A LOT of work before it is usable. I tried it but basically no patch I opened worked. Only patches created in V2.0 worked. So I won't put any hopes up for V2 working anytime soon.
I noticed this, too and pretty much gave up on that menu. Which would be less annoying if i could load a patch by just double clicking on it in the finder...
From my experience the recent menu is completely unreliable. It happened so often that i was working on the wrong versions of patches that I stopped using it completely.
in mac you can drag and drop a patch to an empty patch in axoloti and then open like you would open a subpatch. hacky workaround but better than nothing
another hack is to drag and drop from finder to axoloti menu.
