On/off switch or reset button
Is there a way to connect an on/off switch to the Axoloti core? Are there connectors on the board I could use for this?
I found this solution using a modified USB cable, but I was hoping for something a bit more elegant:
Or can I add a reset button via one of the digital GPIO pins? I couldn't find any objects that can tell the hardware to reboot and wouldn't know how to code my own (if that's even possible).
The reset input is accessible at JP1 (the connector for SWD debugging). A button connecting pin 5(reset) and 3 (gnd) should work.
Though I wonder why one would need to reset/reboot the Axoloti.
Great! Thanks!
It's just as an emergency option, should it crash during a performance, as the new case I've built doesnt allow for easy access to the USB connector for a quick replug.
