Thanks for your response, this is what the log window outputs:
Axoloti version : 1.0.12-2-0-g7975cc87 build time : 29/11/2018 14:38:54 CET
Link to firmware CRC E95BAC96
org.eclipse.jgit.errors.RepositoryNotFoundException: repository not found: C:\Users\Absolutos\Documents\axoloti\axoloti-contrib
at org.eclipse.jgit.lib.BaseRepositoryBuilder.build(BaseRepositoryBuilder.java:582)
at org.eclipse.jgit.api.Git.open(Git.java:116)
at org.eclipse.jgit.api.Git.open(Git.java:99)
at axoloti.utils.AxoGitLibrary.getGit(AxoGitLibrary.java:232)
at axoloti.utils.AxoGitLibrary.getCurrentBranch(AxoGitLibrary.java:181)
at axoloti.MainFrame$4.run(MainFrame.java:317)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
getCurrentBranch cannot find repo FAILED : community
org.eclipse.jgit.errors.RepositoryNotFoundException: repository not found: C:\Users\Absolutos\Documents\axoloti\axoloti-factory
at axoloti.MainFrame$4.run(MainFrame.java:336)
getCurrentBranch cannot find repo FAILED : factory
at axoloti.utils.AxoGitLibrary.sync(AxoGitLibrary.java:67)
at axoloti.MainFrame$4.run(MainFrame.java:346)
sync repo FAILED cannot find submodule : factory (1.0.12,DeGoyen)
at axoloti.utils.AxoGitLibrary.reportStatus(AxoGitLibrary.java:55)
at axoloti.MainFrame$4.run(MainFrame.java:351)
status FAILED cannot find submodule : factory (1.0.12,DeGoyen)
Status : home : OK
status FAILED cannot find submodule : community (1.0.12,anon)
USB device found
connected
Authentic Axoloti Core
search path : C:\Users\Absolutos\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\Absolutos\Documents\axoloti\objects
search path : C:\Users\Absolutos\Documents\axoloti\axoloti-contrib\objects
finished loading objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
