Many thanks.
No change I'm afraid.
Below is the log to show the upgrade to 1.0.9.
After plugging in the 25L the usb midi is dead.
Anything else I should check here? (e.g. Loaded and ran "Noodle Noise" patch to make sure Ax hadn't crashed totally...working fine)
Thought, ....is it possible the 25L just takes too much current?
It seems to be lighting up ok though.
I've just tried plugging 25L & Ax into adjacent usb sockets on my pc. All working, but can't be sure they're on the same current source.
Link to firmware CRC 21C46C25
Status: factory (1.0.9,anon) : OK ( 1.0.8,clean )
Status : home : OK
Status: community (master,anon) : OK ( master,dirty )
Changes for: community (master,anon)
missing: objects/phi
uncommited: objects/phi
search path : C:\Users\Andy\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\Andy\Documents\axoloti\objects
search path : C:\Users\Andy\Documents\axoloti\axoloti-contrib\objects
finished loading objects
USB device found
not accesseable : -12
USB device found
connected
Authentic Axoloti Core
Firmware version: 1.0.0.1, crc=0xA50E988A, entrypoint=0x20011000
Firmware CRC mismatch! Please flash the firmware first! Hardware firmware CRC = A50E988A <> Software CRC = 21C46C25
Start uploading firmware
firmware file path: C:\Program Files (x86)\Axoloti\app\firmware\build\axoloti.bin
firmware file size: 591,292
firmware crc: 0x21C46C25
block uploaded @ 0xC0000000 length 16
block uploaded @ 0xC0000010 length 32768
block uploaded @ 0xC0008010 length 32768
block uploaded @ 0xC0010010 length 32768
block uploaded @ 0xC0018010 length 32768
block uploaded @ 0xC0020010 length 32768
block uploaded @ 0xC0028010 length 32768
block uploaded @ 0xC0030010 length 32768
block uploaded @ 0xC0038010 length 32768
block uploaded @ 0xC0040010 length 32768
block uploaded @ 0xC0048010 length 32768
block uploaded @ 0xC0050010 length 32768
block uploaded @ 0xC0058010 length 32768
block uploaded @ 0xC0060010 length 32768
block uploaded @ 0xC0068010 length 32768
block uploaded @ 0xC0070010 length 32768
block uploaded @ 0xC0078010 length 32768
block uploaded @ 0xC0080010 length 32768
block uploaded @ 0xC0088010 length 32768
block uploaded @ 0xC0090010 length 1468
Done uploading firmware
Start uploading patch
bin path: C:\Program Files (x86)\Axoloti\app\firmware\flasher\flasher_build\flasher.bin
block uploaded @ 0x20011000 length 15188
Done uploading patch
Start flashing...
Firmware flashing in progress, do not unplug the board until the leds stop blinking! You can connect again after the leds stop blinking.
Disconnect request
flashing...
USB device found
connected
Firmware version: 1.0.0.1, crc=0x21C46C25, entrypoint=0x20011000
Axoloti says: USB Device Attached
this will give us more info
