No Compile (OSX 11.6) [Fixed]
Hi Axo's
I want to compile my patch but my computer won't execute the command "make" in the code.
Can Someone help me ?
THX
Start compiling patch
./compile_patch_osx.sh: line 5: 4409 Killed: 9 make -f Makefile.patch
shell task failed, exit value: 137
Compiling patch failed ( /Users/.../Documents/axoloti/Flo/Kobol.axp )
If you have just upgraded to 11.x, you may need to right-click every executable item in the axoloti_runtime directory and allow your operating system to run that program. Apple doesn't allow these to run by default.
It's horrible !!!
There is too many executable.
Thx apple. Too much security kills creativity
Unless I'm mistaken, you can completely disable Gatekeeper, and have all the creativity you like.
I've find the way, Response of @navymaker at the end of the topic :
