When running the following installation command to install debian package, using dpkg, e.g. sudo dpkg -i axoloti_linux_1.012.deb I get the error cannot access file or archive. Is it on another repository ? Or no longer supported ? Thanks
No axoloti app on linux
janvantomme
Not sure if the Axoloti install is available on any package manager on Linux.
The official release can be found on Github, use the 1.0.12 version:
Install guide for Linux:
janvantomme
Don't think you'll need to build it from source. Just download the .deb and .tgz files and follow the instructions.
andrewdovn
Thanks. I cut and paste from the installation script and the underlines don't match the filename (i.e hyphens), so it couldn't find it, I wasn't thinking too carefully.. . Trying to follow the tested ubuntu 14.04 version, but I need an amd64 linux version , so I'll install that and have another go. Thanks again.
