Hello!
I was just trying to connect all three of my Axolotis to my laptop. And I by mistake forgot to change the power of the power supply that is used for the USB-hub to 4.5v. It was on 9v. One of the boards was connected at the time I turned the power supply on..... and now it is not working
Maybe it got too much voltage?
Stupid me, now I am getting the "No available USB device found with matching PID/VID". It does behave the same was as both of my other boards and the LED is steady green, so it seems like it is powered as it should. But it just doesnt connect and it is not available in the "select device" list. Right now I have the board connected directly to the Macbook, to eliminate the usb hub as an issue.
I tried doing the flash rescue, but it seems like it doesnt recognise the board at all. I get this message when trying to do the falsh rescue:
"No devices in DFU mode detected. To bring Axoloti Core in DFU mode, remove power from Axoloti Core, and then connect the micro-USB port to your computer while holding button S1. The LEDs will stay off when in DFU mode."
Have I fried the board totally or what have I done?
Any help appreciated!
Jaffa
