Hoping that some of you good people are experienced in PCB design and I am hoping to get some feedback on my new Axoloti prototype. Currently I am mainly concerned about the SDRAM connections: trace lengths vary between 31 and 58 mm, which from my research should be okay given the "low" clock frequency under 100 MHz.
This is a 4-layer board in the stackup SIG/GND - GND - GND - SIG/3V3. Unusual but I felt the high speed SDRAM traces on the bottom layer do need a good GND reference plane on layer 3 and routing power just by traces seemed a bit messy so I put a power plane on the bottom layer. Putting GND there would have allowed for better shielding I guess but you always need to compromise.
Overall I feel like I made many "not sure if necessary but don't want to risk it" choices, e.g. all the ferrite beads and the separate AGND and 3V3A planes for the audio codec section.
Any thoughts?
