Sorry to comment on this still so late, but just for some clarity: these 1nF capacitors don't have to be 1% tolerance, 5% or even 10% should be fine. Their function is mostly to provide stability to the opamp, and reduce ringing when the input changes, but the exact cut-off frequency doesn't matter.
You can also substitute with polypropylene if C0G/NP0 ceramics are not available. But the ceramics should be cheap, 5% tolerance one are under 10 cents per piece.
