Mtyas contributions
Forum profile : @mtyas
Contributor prefix: mtyas
objects
mtyas/control/oneknob 2func.axs
mtyas/control/tempoclock.axs
mtyas/delay/long-delay.axs
mtyas/dist/StereoTriDistortion.axs
mtyas/reverb/shortverb.axs
patches
none yet
firmware
none yet
status
active
description:
one input to two outputs with memory and soft takeover mode.
useful for adjusting two different parameters with only one knob and a switch.
The value will only change if you catch up to the value it was before you changed output
status
active
description:
switch between internal clock (variable speed) (lfo/square) and midi clock sync (input) with 8 synced tempo variations
status
active
description:
a 10 second mono delay line with feedback, speed and amount inputs. Changing the speed will result in a cheap "tape" speed wobble
mtyas/dist/stereoTriDistortion.axs
status
active
description:
add distortion and grit to any stereo input, with 3 different flavors in parallel, each with adjustable input and output gain
status
active
description:
a 100 wet short strange reverb, with no apparent controls.
Open subpatch to adjust filter/allpass and filter/fdbkcomb ratios for different flavors.
