Hi! I can't load the patch... The console has these messages, my axo is working properly and I synced the library. I'm on osx 10.13.6 it could be a java problem
org.simpleframework.xml.core.ElementException: Element 'modules' does not have a match in class axoloti.object.AxoObjectPatcherObject at line 42
at org.simpleframework.xml.core.Composite.readElement(Composite.java:527)
at org.simpleframework.xml.core.Composite.readElements(Composite.java:445)
at org.simpleframework.xml.core.Composite.access$400(Composite.java:59)
at org.simpleframework.xml.core.Composite$Builder.read(Composite.java:1383)
at org.simpleframework.xml.core.Composite.read(Composite.java:201)
at org.simpleframework.xml.core.Composite.read(Composite.java:148)
at org.simpleframework.xml.core.Composite.readVariable(Composite.java:623)
at org.simpleframework.xml.core.Composite.readInstance(Composite.java:573)
at org.simpleframework.xml.core.Composite.readUnion(Composite.java:549)
at org.simpleframework.xml.core.Composite.readElement(Composite.java:532)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:190)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:167)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:144)
at org.simpleframework.xml.core.CompositeListUnion.readElement(CompositeListUnion.java:189)
at org.simpleframework.xml.core.CompositeListUnion.read(CompositeListUnion.java:162)
at org.simpleframework.xml.core.Variable$Adapter.read(Variable.java:482)
at org.simpleframework.xml.core.Composite.readVariable(Composite.java:613)
at axoloti.PatchGUI.OpenPatchInvisible(PatchGUI.java:1003)
at axoloti.PatchGUI.OpenPatch(PatchGUI.java:1025)
at axoloti.FileUtils.Open(FileUtils.java:166)
at axoloti.menus.FileMenu.jMenuOpenActionPerformed(FileMenu.java:255)
at axoloti.menus.FileMenu.access$200(FileMenu.java:51)
at axoloti.menus.FileMenu$3.actionPerformed(FileMenu.java:107)
at com.apple.laf.ScreenMenuItem.actionPerformed(ScreenMenuItem.java:125)
at java.awt.MenuItem.processActionEvent(MenuItem.java:669)
at java.awt.MenuItem.processEvent(MenuItem.java:628)
at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:351)
at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:339)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:761)
