I use this quite frequently, very useful. Too bad it doesn't handle realtime messages, is it because the code to send the messages through isn't quick enough?
I've using several objects in the same project to turn my Axo into a one in three out-box, works great if all the three connections are used but makes the axo crash (!) when one or more aren't. I believe the error messages that showed up in the log were something like ring buffer error but I can't confirm right now.
