Hello,
I plan to use the Axoloti as a MIDI thru box that will filter out some events (among other things).
In a scenario, I want to filter out all clock data, and start/stop messages (I send clock to an Arturia Keystep to sync its arpeggiator but it sends back the clock in the system, which is an unwanted behavior for me). The Axoloti would be at the MIDI OUT of the Keystep. (This is the exact opposite of what's been asked in a similar topic and unfortunately not really answered).
I tried making a patch but I can't test it as I don't have the device yet.
I just want to make sure I understood everything correctly:
- Bend will be routed to bend (but channel will be reaffected and I don't want that)
- Same for CC
- Same for PGM change
- Same for note (but there's no identity between in/keyb and out/note)
- Midi in/clock won't be routed to out/clock (and could probably be deleted?)
Some questions:
- Is there a way to do that without changing MIDI channel ? I plan to play with the Keystep on several channels and don't want that info to be lost in translation.
- Is the general idea of the patch OK or have I missed something?
Thanks !
