I know there have been discussions on increasing midi inputs into the Axoloti, and different ideas around it, so I guess this topic is not new, but look at it specifically as a unit with multiple 5 pin din inputs and one 5 pin din output, Yes there are some midi merge units to purchase, but they are quite pricy and don't seam to be many options. But considering some of the work I have done learning to use midi with Arduino or similar dev board, somehow it seams as though it would not be too difficult to build especially if i just focused to begin with on CC and Note messages.
The biggest challenge I would see is getting the code right, to ensure the relevant data packages are kept together, and that you are regularly cycling through every input to look for messages.
Has anyone tried anything like this, is there something I am missing ?
