how can i route all Midi DIN In Data directly to the Midi DIN Out ?
Best
Mario
I would think you just make the following objects: midi/in/cc, midi/in/keyb, midi/in/clock, midi/in/bend and midi/out/cc, midi/out/note, midi/out/clock, midi/out/bend and connect them respectively.
Only just started with Axoloti today though so there is probably a better way.
O.K. Thanks. I tried it, but it doesn't work. I think I make some mistakes.
Is there a hardware solution for it, without using the patcher.
I wanna send the data of a master keyboard with pitch and mod wheel directly to the DIN Output.
