Here's what my code ended up looking like in the end
#include <MIDI.h>
#include "Controller.h"
MIDI CONTROLLER
by Notes and Volts
www.notesandvolts.com
Version 1.2 **Arduino UNO ONLY!**
MIDI_CREATE_DEFAULT_INSTANCE();
//***SET THE NUMBER OF CONTROLS USED**************************
//---How many buttons are connected directly to pins?---------
byte NUMBER_BUTTONS = 0;
//---How many potentiometers are connected directly to pins?--
byte NUMBER_POTS = 0;
//---How many buttons are connected to a multiplexer?---------
byte NUMBER_MUX_BUTTONS = 6;
//---How many potentiometers are connected to a multiplexer?--
byte NUMBER_MUX_POTS = 12;
//***ANY MULTIPLEXERS? (74HC4067)************************************
//MUX address pins must be connected to Arduino UNO pins 2,3,4,5
//A0 = PIN2, A1 = PIN3, A2 = PIN4, A3 = PIN5
//Mux NAME (OUTPUT PIN, , How Many Mux Pins?(8 or 16) , Is It Analog?);
Mux M1(10, 16, false); //Digital multiplexer on Arduino pin 10
Mux M2(A5, 16, true); //Analog multiplexer on Arduino analog pin A0
//***DEFINE DIRECTLY CONNECTED POTENTIOMETERS************************
//Pot (Pin Number, Command, CC Control, Channel Number)
//**Command parameter is for future use**
//Pot PO1(A0, 0, 1, 1);
//Pot PO2(A1, 0, 10, 1);
//Pot PO3(A2, 0, 22, 1);
//Pot PO4(A3, 0, 118, 1);
//Pot PO5(A4, 0, 30, 1);
//Pot PO6(A5, 0, 31, 1);
//Add pots used to array below like this-> Pot *POTS[] {&PO1, &PO2, &PO3, &PO4, &PO5, &PO6};
Pot *POTS[] {};
//***DEFINE DIRECTLY CONNECTED BUTTONS*******************************
//Button (Pin Number, Command, Note Number, Channel, Debounce Time)
//** Command parameter 0=NOTE 1=CC 2=Toggle CC **
//Button BU1(2, 0, 60, 1, 5 );
//Button BU2(3, 0, 61, 1, 5 );
//Button BU3(4, 0, 62, 1, 5 );
//Button BU4(5, 0, 63, 1, 5 );
//Button BU5(6, 0, 64, 1, 5 );
//Button BU6(7, 0, 65, 1, 5 );
//Button BU7(8, 1, 64, 1, 5 );
//Button BU8(9, 2, 64, 1, 5 );
//Add buttons used to array below like this-> Button *BUTTONS[] {&BU1, &BU2, &BU3, &BU4, &BU5, &BU6, &BU7, &BU8};
Button *BUTTONS[] {};
//***DEFINE BUTTONS CONNECTED TO MULTIPLEXER*************************
//Button::Button(Mux mux, byte muxpin, byte command, byte value, byte channel, byte debounce)
Button MBU1(M1, 0, 0, 70, 1, 5);
Button MBU2(M1, 1, 1, 71, 1, 5);
Button MBU3(M1, 2, 2, 72, 1, 5);
Button MBU4(M1, 3, 0, 73, 1, 5);
Button MBU5(M1, 4, 0, 74, 1, 5);
Button MBU6(M1, 5, 0, 75, 1, 5);
//Button MBU7(M1, 6, 0, 76, 1, 5);
//Button MBU8(M1, 7, 0, 77, 1, 5);
//Button MBU9(M1, 8, 0, 78, 1, 5);
//Button MBU10(M1, 9, 0, 79, 1, 5);
//Button MBU11(M1, 10, 0, 80, 1, 5);
//Button MBU12(M1, 11, 0, 81, 1, 5);
//Button MBU13(M1, 12, 0, 82, 1, 5);
//Button MBU14(M1, 13, 0, 83, 1, 5);
//Button MBU15(M1, 14, 0, 84, 1, 5);
//Button MBU16(M1, 15, 0, 85, 1, 5);
////Add multiplexed buttons used to array below like this-> Button *MUXBUTTONS[] {&MBU1, &MBU2, &MBU3, &MBU4, &MBU5, &MBU6.....};
Button *MUXBUTTONS[] {&MBU1, &MBU2, &MBU3, &MBU4, &MBU5, &MBU6};
//***DEFINE POTENTIOMETERS CONNECTED TO MULTIPLEXER*******************
//Pot::Pot(Mux mux, byte muxpin, byte command, byte control, byte channel)
Pot MPO1(M2, 0, 0, 100, 1);
Pot MPO2(M2, 1, 0, 101, 1);
Pot MPO3(M2, 2, 0, 102, 1);
Pot MPO4(M2, 3, 0, 103, 1);
Pot MPO5(M2, 4, 0, 104, 1);
Pot MPO6(M2, 5, 0, 105, 1);
Pot MPO7(M2, 6, 0, 106, 1);
Pot MPO8(M2, 7, 0, 107, 1);
Pot MPO9(M2, 8, 0, 108, 1);
Pot MPO10(M2, 9, 0, 109, 1);
Pot MPO11(M2, 10, 0, 110, 1);
Pot MPO12(M2, 11, 0, 111, 1);
//Pot MPO13(M2, 12, 0, 50, 1);
//Pot MPO14(M2, 13, 0, 55, 2);
//Pot MPO15(M2, 14, 0, 50, 1);
//Pot MPO16(M2, 15, 0, 55, 2);
//Add multiplexed pots used to array below like this-> Pot *MUXPOTS[] {&MPO1, &MPO2, &MPO3, &MPO4, &MPO5, &MPO6.....};
Pot *MUXPOTS[] {&MPO1, &MPO2, &MPO3, &MPO4, &MPO5, &MPO6, &MPO7, &MPO8, &MPO9, &MPO10, &MPO11, &MPO12};
void setup() {
MIDI.begin(MIDI_CHANNEL_OFF);
void loop() {
if (NUMBER_BUTTONS != 0) updateButtons();
if (NUMBER_POTS != 0) updatePots();
if (NUMBER_MUX_BUTTONS != 0) updateMuxButtons();
if (NUMBER_MUX_POTS != 0) updateMuxPots();
void updateButtons() {
// Cycle through Button array
for (int i = 0; i < NUMBER_BUTTONS; i = i + 1) {
byte message = BUTTONS[i]->getValue();
// Button is pressed
if (message == 0) {
switch (BUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
break;
case 1: //CC
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
break;
case 2: //Toggle
if (BUTTONS[i]->Btoggle == 0) {
BUTTONS[i]->Btoggle = 1;
else if (BUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
BUTTONS[i]->Btoggle = 0;
break;
// Button is not pressed
if (message == 1) {
case 0:
MIDI.sendNoteOff(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
break;
case 1:
break;
void updateMuxButtons() {
// Cycle through Mux Button array
for (int i = 0; i < NUMBER_MUX_BUTTONS; i = i + 1) {
MUXBUTTONS[i]->muxUpdate();
byte message = MUXBUTTONS[i]->getValue();
if (message == 0) {
switch (MUXBUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
break;
case 1: //CC
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
break;
case 2: //Toggle
if (MUXBUTTONS[i]->Btoggle == 0) {
MUXBUTTONS[i]->Btoggle = 1;
else if (MUXBUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
MUXBUTTONS[i]->Btoggle = 0;
break;
if (message == 1) {
case 0:
MIDI.sendNoteOff(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
break;
case 1:
break;
void updatePots() {
for (int i = 0; i < NUMBER_POTS; i = i + 1) {
byte potmessage = POTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(POTS[i]->Pcontrol, potmessage, POTS[i]->Pchannel);
void updateMuxPots() {
for (int i = 0; i < NUMBER_MUX_POTS; i = i + 1) {
MUXPOTS[i]->muxUpdate();
byte potmessage = MUXPOTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(MUXPOTS[i]->Pcontrol, potmessage, MUXPOTS[i]->Pchannel);
