Microtonal patches broken in 2.0
@Blindsmyth shared this patches a while ago
"maquam synthesizer patch from music tech fest 2016 that contains @johannes scala file importer".
They were perfectly working in Axoloti 1.x . Also other patches using similar system and for some reason , all of them fail to compile for me . In this case(Error 1 - "maqam synthesizer.axp") I'm getting some sort of java related error after compiling the patch successfully (?¿) but axoloti gets disconnected and doesn't go Live .
With another patch approach the problem seems to be related to arrays and could be a simple question of changes in the syntax or something like it . I would love to use this patches with 2.0 .
The original Forum post where the patches also are is Here
[Error 1]
section size addr
.text 12288 0
.rodata 2004 0
.data 1080 0
.bss 1632 0
.init_array 0 0
.fini_array 0 0
.comment 128 0
.ARM.attributes 57 0
Total 17189
Done compiling patch
java.io.IOException: Not connected
at axoloti.connection.USBBulkConnection_v2.transmitPacket1(USBBulkConnection_v2.java:415)
at axoloti.connection.USBBulkConnection_v2.sendAndGetReplyPtr(USBBulkConnection_v2.java:677)
at axoloti.connection.USBBulkConnection_v2.mem_alloc(USBBulkConnection_v2.java:797)
at axoloti.connection.USBBulkConnection_v2.transmitStartLive(USBBulkConnection_v2.java:694)
at axoloti.live.patch.PatchViewLive.lambda$goLive$9(PatchViewLive.java:314)
at axoloti.job.JobProcessor.lambda$exec$0(JobProcessor.java:21)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
[Error 2]
C:\Users\x\DOCUME~1\AXOLOT~1.0/build/xpatch.cpp: In member function 'int rootc::instancestrings::init(rootc*)':
C:\Users\x\DOCUME~1\AXOLOT~1.0/build/xpatch.cpp:2783:21: error: '_array' was not declared in this scope
int rem_sz = sizeof(_array[0]);
C:\Users\x\DOCUME~1\AXOLOT~1.0/build/xpatch.cpp:2783:21: note: suggested alternative: 'array'
array
C:\Users\x\DOCUME~1\AXOLOT~1.0/build/xpatch.cpp:2786:21: error: 'fbuff' was not declared in this scope
if (rem_sz>sizeof(fbuff)) {
C:\Users\x\DOCUME~1\AXOLOT~1.0/build/xpatch.cpp: In member function 'void rootc::instancepatcher__1::voice::instancetabread1::dsp(rootc::instancepatcher__1::voice*, int32_t, int32_t&)':
C:\Users\x\DOCUME~1\AXOLOT~1.0/build/xpatch.cpp:3670:22: error: 'class rootc::instancepatcher__1::voice' has no member named 'parent'
outlet_o= parent->parent->instancetuning_i.array[_USAT(inleta,parent->parent->instancetuning_i.LENGTHPOW)]<parent->instancetuning_i.GAIN;
In file included from C:\PROGRA~2\Axoloti\app\api/CMSIS/Core/Include/cmsis_compiler.h:54:0,
from C:\PROGRA~2\Axoloti\app\api/CMSIS/Core/Include/core_cm4.h:162,
from C:\PROGRA~2\Axoloti\app\api/stm32f4xx/stm32f427xx.h:190,
from C:\PROGRA~2\Axoloti\app\api/stm32f4xx/stm32f4xx.h:155,
from C:\PROGRA~2\Axoloti\app\api/axoloti_math.h:22,
from C:\PROGRA~2\Axoloti\app\api/axoloti_filters.h:30,
from C:\PROGRA~2\Axoloti\app\api/xpatch.h:10,
Quite a few things are broken in 2.0, better to stick to 1.0.12 at the moment.
Can you post the patches that are not working here? Might be easier for people to look into what objects are causing the error and fix them.
Maqam Synthesizer.axp (17.1 KB)
this is the error 1 previously mentioned
