Making k-rate inputs s-rate
Is there an easy way to make k-rate inputs s-rate? I want to be able to modulate the pulse width of osc/pwm in audio rate, but when I try I get this ugly tone that I assume is the k-rate limitations. I took a look at the code, but most of it seems to be k-rate already (with buffers), so I'm not too sure where to start. I've also noticed that some k-rate (blue) devices will automatically convert to s-rate (red) inlets/outlets. How does that work?
that's just the patcher replacing the k-rate object with the s-rate equivalent. no voodoo here :slight_smile:
if there is no s-rate version the colours don't change.
Another question: Are the blue ports and red ports the same as k-rate and s-rate? Or is there a difference?
What happens when I plug a red port into a blue port? Does the blue port only check the value at 1/16th rate?
What happens when I plug a blue port into a red port? Does it interpolate to fill in the gaps?
Do I want to keep my entire signal chain composed of red ports if I want to retain audio-rate modulation abilities?
blue, (and green) are k-rate. red input or output means the signal is s-rate.
Check out the User Guide, sections "Connection (and Inlet/Outlet types)" and "Connections between different types"
No, you need to use the conv/interp object to convert from blue to red with interpolation.
That's an interesting question. I depends on the kind of modulation you use, and how precise you need it to be. For instance, if you modulate with a k-rate sine wave, and use conv/interp, you are going to get a "reasonable" version of a sine wave. But if you need a sawtooth with a vertical edge, you can't use lfo/saw cheap: the conv/interp will transform the vertical edge to a line, going from 64 to -64 in 16 samples. In that case, you would use an osc/phasor.
So S-rate -> K-rate is reducing the sampling rate to 3000hz? Does that mean there will be aliasing artifacts, or is it more akin to a lowpass?
Also, I figured out how to make my oscillators audio-rate. You have to embed it (so your changes only affect it), change the inlet type to frac32_buffer, and make some code edits:
Aliasing. Essentially, k-rate signals are sampled at the k-rate, so using them on s-rate inputs will be the same as if they'd been downsampled.
