Loop midi with jt/midi/play or equivalent
Hello,
I can load a midi file with jt/midi/play and play it, even on startup axoloti standalone, that's great.
But I'd like to loop it !
Any way this may be possible ?
if jt/midi/play sent a signal when the midi was finished, I could use that.
I could even use a timer to retrigger the midi, as I know its length.
Any ideas?
Thank you
Try this. You can set the logic/counter object to something like 30 at first just to see if this method works. If it doesn't, click the tab at the top of jt/midi/play and click "help" to see how it works and fiddle around with it. I can't test it out right now, but I've done something similar before.
Thank you,
It does not seem to work as expected, the MIDI starts when the counter goes back to 0, and stops inmediately.
I haven't used Axoloti a lot yet, closest I've used is PD, and I get a tad confused about connection types, but, as far as I understand yellow is a gate-like boolean. 'Counter''s yellow ouput's tooltip is 'carry pulse' also it has a particular symbol next to it.
I am not sure which display object would help me understand what this output spits, but I'd say it probably is a toggle that goes ON when the counter ends, and OFF right away.
As what works with the midi player is a toggle, I'd say that what I need is the opposite, something that stays ON, then goes OFF briefly, and ON again.
Perhaps I can invert the 'carry pulse' output ?
Thank you
Well, there IS a yellow inverter, and yeah, it works as expected :smiley: good for me!
Thank you for your help.
@hitachii, I actually have another question/doubt regarding this, but I figured out I may better write a separate post here. Perhaps you may help aswell.
Thanks again
