Load sample from Sd to waveplayer crashes
#41
File format is fine... sd card formatted its not that i not have done those things... im not that noob... and have tried the obvius things before writing here....
#42
I'm getting those errors when trying to use a 16/48khz file. Should this be fixed in 1.08? I'm formatting from audacity choosing raw and 'signed 16 bit' - I've tried with raw and wav extensions but either way I get the following error:
Control transfer failed: -9
Disconnect request
Control transfer failed: -4
Card was formatted by axoloti and gets the following benchmarks:
Axoloti says: open : 611 ms
Axoloti says: write BW : 460 kB/s
Axoloti says: close : 6 ms
Axoloti says: open : 24 ms
Axoloti says: read BW : 1956 kB/s
#43
File format is not suspect, any file - like a powerpoint presentation - would be played, likely only resulting in noise or glitchy sounds, but not a crash. If the samplerate 'd be off, it would still play but transposed. If it'd be a 32 bit raw file, it'd sound distorted and at half speed. Play a .wav file, and you will get a click resulting from the file header played back.
1.0.8 is improved in reporting file access errors, and also added support for long filenames. 1.0.6 is limited to 8 character filenames with a 3 character extension.
#44
Hmm.. well I'm using 1.08 so I wonder what the problem is. I'm trying to run the demo patch mentioned earlier in this thread.
