not sure what I'm overlooking here.
after doing:
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppa
sudo apt-get update
sudo apt-get install gcc-arm-embedded
i get:
Axoloti version : 1.0.12-2-0-g7975cc87 build time : 09/04/2018 13:05:40 UTC
Link to firmware CRC E95BAC96
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
connected
Authentic Axoloti Core
search path : /home/tim/axoloti/axoloti-factory/objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
search path : /home/tim/axoloti/objects
search path : /home/tim/axoloti/axoloti-contrib/objects
finished loading objects
Generate code complete
Creating directory on sdcard : /untitled
Done creating directory
Changing working directory on sdcard : /untitled
Start compiling patch
Compiling patch... with /opt/Axoloti/app/firmware
BDIR = /home/tim/axoloti/build
FIRMWARE = .
Build precompiled header
arm-none-eabi-g++ -nostdlib -fno-exceptions -fno-rtti -mcpu=cortex-m4 -O3 -fomit-frame-pointer -falign-functions=16 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Wunused-parameter -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -DTHUMB -std=c++11 -DARM_MATH_CM4 -D__FPU_PRESENT -fno-math-errno -fno-threadsafe-statics -fno-use-cxa-atexit -Wno-unused-parameter -I/opt/Axoloti/app/CMSIS/Include -I/opt/Axoloti/app/CMSIS/DSP_Lib/Include -I/opt/Axoloti/app/chibios/os/ports/common/ARMCMx/CMSIS/include -I/opt/Axoloti/app/chibios/os/ports/common/ARMCMx -I/opt/Axoloti/app/chibios/os/ports/GCC/ARMCMx -I/opt/Axoloti/app/chibios/os/ports/GCC/ARMCMx/STM32F4xx -I/opt/Axoloti/app/chibios/os/kernel/include -I/opt/Axoloti/app/chibios/os/hal/include -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32F4xx -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32 -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32/GPIOv2 -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32/I2Cv1 -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32/OTGv1 -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32/RTCv2 -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32/SPIv1 -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32/TIMv1 -I/opt/Axoloti/app/chibios/os/hal/platforms/STM32/USARTv1 -I/opt/Axoloti/app/chibios/boards/ST_STM32F4_DISCOVERY -I/opt/Axoloti/app/chibios/ext/fatfs/src -I. -I/opt/Axoloti/app/chibios -I./mutable_instruments -Winvalid-pch -MD -MP -c ./xpatch.h -o /home/tim/axoloti/build/xpatch.h.gch
In file included from ./axoloti.h:24:0,
from ./xpatch.h:3:
./axoloti_math.h:180:0: warning: "RAND_MAX" redefined
#define RAND_MAX INT32_MAX
In file included from /usr/arm-none-eabi/include/c++/7.3.1/bits/std_abs.h:38:0,
from /usr/arm-none-eabi/include/c++/7.3.1/cmath:47,
from /usr/arm-none-eabi/include/c++/7.3.1/math.h:36,
from /usr/arm-none-eabi/include/fastmath.h:7,
from ./axoloti.h:21,
from ./xpatch.h:3:
/usr/arm-none-eabi/include/stdlib.h:63:0: note: this is the location of the previous definition
#define RAND_MAX _RANDMAX
from ./xpatch.h:3:
./axoloti_math.h: In function 'int rand()':
./axoloti_math.h:181:57: error: 'int rand()' was declared 'extern' and later 'static' [-fpermissive]
attribute ( ( always_inline ) ) _STATICINLINE int rand(void) {
from ./xpatch.h:3:
/usr/arm-none-eabi/include/stdlib.h:140:5: note: previous declaration of 'int rand()'
int rand (void);
make: *** [/home/tim/axoloti/build/xpatch.h.gch] Error 1
Makefile.patch:53: recipe for target '/home/tim/axoloti/build/xpatch.h.gch' failed
