The subject practically says it all.
If I pass the LFO signal through a full wave rectifier, I will end up with a positive signal that I should be able to connect to an analogue input on the Axo.
Things I believe I need to be careful of,
- Ensuring I work to a 0v to 3.3V range.
- Protection against any voltage spikes.
- Keeping frequency well within the K rate.
The idea is to have a kind of crude external audio source that I can use as an LFO to work through the patch.
Has anyone tried anything like this ?
