Killed voltage regulator, and possibly more
So I have been playing with my axoloti for a month or so without any issues, but it suddenly stopped working yesterday & the voltage regulator is getting really hot. I have been using a teensy 3.6 as a usb midi controller running into the usb host port for extra controls powering the teensy from the host port. I have been powering the axoloti through the micro usb port with a usb power brick as is was a pretty simple solution for portable jamming.
I had run separate 5v to the teensy at some point during the build process, but ran into pretty serious ground loop type noise, so I just ended up running it off the host port instead.
I have another 2 axolotis on the way to me now, and wanted to know:
-Is there a solution for me to keep this from happening again?
-Would powering it from a 9v source change anything?
-Is there a way to avoid the noise I was getting when using a separate power source to the teensy?
Also, I took a look at the schematic and it appears to be the 3v regulator (ld117as33tr), would there be any other components I should look at replacing if I where to attempt to repair this board? I haven't had the chance to take any voltage readings yet, but the only part getting noticeably hot was the regulator. Is it even worth trying?
Thanks for any help!
