New additions - 2 interped dials, uni/bip
Search:
jaffa/ctrl/dial i
jaffa/ctrl/dial i2
Search:
jaffa/ctrl/dial i
jaffa/ctrl/dial i2
New additions - Many midi note outs combined in 1 object.
Search:
jaffa/ctrl/note2
jaffa/ctrl/note4
jaffa/ctrl/note8
New additions - Modulo, Pow(2), displays & strings.
Search:
jaffa/math/modulo
jaffa/math/POW3
jaffa/disp/d4a
jaffa/disp/d4b
jaffa/disp/d4c
jaffa/disp/d4d
jaffa/disp/d4e
jaffa/string/c2
jaffa/string/c4
jaffa/string/c8
Wuhuu rounded the 2k views. Thanks
Seems like it might be time for some new objects......
Stay tuned...
New additions - Simple samplers
Search:
jaffa/sam/simsam1
jaffa/sam/simsam2
jaffa/sam/simsam3
jaffa/sam/simsam4
A couple of different versions of the simsam1 I uploaded a while ago, with different kind of setups.
Very easy to use. See the help file.
New additions - 6 Voice Karplus "String" algorithm
This is a subpatch and is only available here, its not in the library.
It's a 6 voice polyphonic karplus strong. Its set up to use midi input, each "string" is plucked by playing a note on the keyboard.. There is an lfo pr. voice, for some "liveliness". Got a pretty nice "twang" to it......
Karplus-String-6-Voice.axp (16.1 KB)
New additions - pyramid number sequencer.
Search: jaffa/math/pyramid
This is a Pyramid number sequencer, where the length of the sequence is based on how many numbers there are in the sequence. Examples:
1
1,2
1,2,3
1,2,3,4
1,2,3,4,5
1,2,3,4,5,6
etc.
You input an integer variable in one end and you get this list out in the other end. The l output is the length of the sequence currently selected, the s outputs the selected number in the sequence.
Thanks to @Captain_Burek for helping me realise this into a proper object, my own table version basically sucked. It worked but was highly inefficient.
New additions - equal powered crossfaders + equal power scaler.
**Search: **
jaffa/math/ep1
jaffa/mix/xfade2
jaffa/mix/xfade3
These are equal powered crossfaders and an equal power math function. I think its called equal powered, but I am not sure. It's basically the last 1/4 of a cosine wave, isolated and used for scaling the crossfader input. I tried graphing the function using an envelope:
pyramid this would be really cool with a midi input... i beeing the number of notes pressed together, and with s being being the note order values of notes beeing pressed together.
Yes I build something similar to that in Pure data. I made it for recording chords into a polyphonic sequencer. I had to make sure that there was ONLY send data to to note 2 and 3 tables when note 2 & 3 were actually hold down.
AHA moment:
It could also works as a "standard" polyphonic distributor for subpatches.
By that I mean, if one wants to make polyphonic stuff without using axolotis own poly systemm which has some limitations, then this could be used to route stuff to the right voice subpatches.
@philoop, lets turn it into an object. Would you care to chime in? I got a naive implementation here, the only thing I am missing is a trigger on note OFF.... So if you have an idea how to make "trigger on note off" I think we got it. Again, this is naive approach, we can always optimize it, lets just get it working first.
It's basically a "note on counter", every time you push a note, the counter will take a step forward, every time you release a note, it will take a step backwards. Another function latches the values of the notes hold, as you described.
Note counter.axp (15.5 KB)
Any suggestions for the note off trigger?
Hi Jaffa, I really like your 8 waves morphable wavetable oscillator (m8v1). I'm using in various patches and I want to ask if you could made a version with less waves... Depending on the situation 2, 3 or 4 waves are enough for me, and found that setting all 8 waves are a bit time consuming, and the morphing becomes narrow (if I don't set all waves). May be you could do a module with only 2 waves, and one with 4, or the same 8 waves module but with a selector for the amount of waves you want to use.
Thanks!!!
Hey @Sebo
Here is a subpatched version with only 4 waves. I dont remember if I made object versions of the smaller ones, I am going to have to look for it then or make it.
But you can try this subpatch to start with:
Wavetable morph 4 waves for com 2 .axp (19.9 KB)
Thank you very much!!!
A 2 waves version will be great, but the 4 waves version will do my life easier
Well to make the version with 2 waves its really simple. You just make 2 wavetables and use the crossfade objet to fade from one to the other.
Wavetable morph 2 waves 1 .axp (13.2 KB)
I thought that crossfading 2 wavetable objets will introduce phasing in the resulting wave, as are 2 independent oscillators, but I tried and works well.
Thank you!
It probably could, yes. But I didnt encounter any issues. You can always use the rst inlet to restart the osc's phase if it is a problem.
