New addition - Random pattern player!
Search: jaffa/rand/rp128II
This is a random pattern player ala the random pattern from the G2. You have 100 random patterns, which you need to download from the link below. Each pattern consists of 128 random numbers, with values between 0 and 64.
So 100X128 patterns with random values in the range 0-64!!!!
NB: USES FILES FROM SD-CARD!
How to:
1. Download & uncompress the tab files.
2. Put the "Tab" folder in the root of the SD-card.
3. Open an Axoloti patch and type in tnbe object browser; jaffa/rand/rp128II
4. Open the help file and go live. If you placed the "Tab" folder in the root, you should see
random patterns in the display.
Note, that if you want to place the tab files in your own location on SD-card, you have to edit the object. Then you must copy the object to your local folder and edit it from there. Since this object uses a table, you cannot embed the object, it wont work. So copy it to local library and then edit your own version and remember to save before exiting the object editor.
The tab files - UPDATED - The last link was made on wetransfer and had expired. This new link is permanent:
https://mega.nz/#!qRJkWICS!90LgdGTtZZctnA3AI8g5GanBcJLPB_7YxBYlG49OPZg
Nb. For the purists, pattern 6 and 7 are the same. For some reason I skipped 007 when creating the patterns, so I just copied the 6 to 7, so there aren't any gaps.
