I love this patch, want to try it! Is it posted anywhere? Thanks
Is this guitar delay/fx patch posted anywhere?
Blindsmyth
yes it is, glad you like it!
I posted the patch here:
but it is a big chaotic mess, my patching go a lot more organized
These are the main building blocks, this subpatch records samples as long as you press rec with the next trigger from a sequence and then retriggers the sample and plays it back in different octaves.
If you then run this through vca env and filter env triggered from the same sequence you get the synth like sounds of the patch.
L Lpsmpl 4_0.axs (13.3 KB)
This is the delay fx 'm using:
SyncedTapeDly-0.1.3.axs (14.5 KB)
