Hi, I had really great time using my first axoloti this year, so when the last batch came out, I recommend to a great friend to buy one and start to build his own synth. But he is in a great trouble because his circuit didn't worked. It was his first soldering project so I was thinking about a bad solder join somewhere, I've redo all the circuit myself after I cleaned it up, nothing changed...
Here is a pictures of the circuit :
Mounted like that :
All poti are 10k. I've tried with all VDD and GND. I'm 100% sure it's not the female hader on the board because I've tried all analog in individually with a breadboard and all worked finely. I've watched carefully if any wire touch another one, it's clean.
Maybe it's because he used this for wiring ? : http://www.e44.com/outillage/realisation-circuit-imprime/plaques-d-experimentations/lot-100-strap-en-bande-0.6mm-52mm-max-7.5a-jumper-JUMPER-100.html
Somebody have an idea to save my friend from his hard impatience ?
Cheers
