Can anyone explain why this happens?
Or atleast how to get the same number.
Int to fractional confusion (solved)
MrBim
because the float has to represents floating point numbers, to do this its representation is different.
in particular they are shifted 21 bits to the left.
e.g 1 << 21 = 1, 1 << 20 = 0.5 , and 1 << 22 = 2
this is a good explanation of the format, the float would be Q21
toneburst
I must admit, when working on custom objects, I tent to ignore the way numbers are represented in the UI, and just treat them as 27 bit signed/unsigned integers internally (i.e. in the object code).
a|x
Trying to understand the factory dist:soft object
MrBim
hooray it has totally solved my problem.
just add a math/>> 21and it reads as i want it to.
