quick question, related to running 4 boards (and PI/other board) off a 7 port USB powered hub. (rated at 2A)
so when I power everything up, boards are all at 4.93-4.98V, so this seems fine.
sometimes I see one start lower, around 4.85V, but seems to then rise up to 4.9+v, perhaps related to SDCard... anyway no matters, it seems ok.
what I want to know is, is there any danger if you run them under voltage (short period) e.g. around 3.5V
Im not doing this on purpose!
BUT Ive noticed, if I 'forget' and unplug the USB hubs supply, before I disconnect the host USB cable, it powers the boards off the host (another powered hub in this case), and boards all continue to run, but of course drop to 3.5V, as it can only supply 500ma (or 1a I think on charging port)
could this damage anything?
(Im not worried about the hub that ends up powering it, only the axoloti boards
again, this is not 'normal' running, just if its 'accidental'... so do I have to be extremely careful about this?
(or are the boards, just not going to work correctly etc.)
