I am working on a project that uses lasers to trigger midi notes. I would like a physical switch that selects between different instruments, and two other physical switches that can change the parameters of the sound, e.g attack, release. I would like the project to have a built in speaker, but have the option of switching to external speakers, anyone know if I can achieve these things with the Axoloti? Thanks in advance!
Inexperienced, and need advice on capabilities of Axoloti core
servandisco
all of this can be done easily but you will need a little amp for the "internal" speaker. (can be a 5v integrated amp powered by axo)
also, what do you mean by "switch"?. a two position switch? / momentary? , still, yes, it can be done.
Hi, thanks for response! I intend to use a physical 3 way switch to select instrument. As for the sound parameters I was hoping that these could be some sort of slider? so that they can be controlled "live" as it were. Do you know of any similar pojects that I could have a look at?
Indeed it is. Only trouble is I have no experience coding so no idea how to start getting all controls to work how I want them
