hi,
i would like to be able to adjust the headphone-out level independent from audio out-level - is that possible and where can i find more info about that?
thanks in advance.
best
og
hi,
thanks in advance.
best
og
You can do that with the audio/outconfig object. Fixed settings only, so no control with a potentiometer possible.
hi,
thanks for your answer.
i would like to be able to do that while running (without computer) - that won't be possible with that module - any way how i could get that done?
best
og
Won't be possible.
You could set it full volume with that object and use one of these passive attenuation knobs for control.
hi,
thanks again for your reply!
your advice seems to be a good workaround - hoped to get it done within the device
best
olaf
