OK, thanks that's what I needed to know, running it in an effects loop sounds like the best way, though some of the amps I use don't have one,
Pickup loading is the main issue, which I can sort with a buffer before the Axoloti, when I'm not using it in effects loop.
One Strymon delay or reverb costs at least $600 AUD and I figured they must be built around some generic DSP board.
So I thought there might be an open source DSP board that could do it and be much cheaper, and much more flexible.
One google search and I found Axoloti, saved me building one myself , and the years of work developing the software.
The other thing I wanted to use Axoloti for was as a mastering EQ, compressor, exciter and stereo enhancer for live gigs, for that I'll need a preamp with XLR and balanced TRS jacks and some sort of converter from balanced to unbalanced and back again.
Does such a thing exist?
I could build it myself given schematics but my analog electronics design is not that sophisticated yet.
I'm very impressed and pleased that you guys are so helpful and quick to respond, thanks,
IMHO this sort of support and an active helpful community of users is as important as the hardware itself.
Awesome
