Hello all, as I said in the previous thread (when I stupidly broken the firmware upload) I have this hardware button connected to PB9 and I haven't been able to unlink it from changing the patch to the start patch on the SD card or the flash patch in case the SD card is not present.
As far as I can tell I have no controller patch and in the current patch I send to the board there's no use of gpio/in/digital PB9, or if present, for example connected to a disp/bool, it doesn't do that and continue to change the patch and thus disconnects the editor, where I see
Control transfer failed: -4
Disconnect request
so, my question is: is there a possibility that with my weak soldering skills I have connected it in a way that does what it does? I think it's very unlikely. So, it must be something software, but I can't understand for the life of me what is happening....
Can you help me?
Is there a way to completely reset any input function?
Thanks in advance
although I would have rather know what was happening...
