Hey
I sometimes get some clicks when using the table/play object. When retriggering "start" with lfo/sq for example. I read in here that I can use a window object to remove those clicks and that I should look in example 22_overlap_add_shifter. And I have checked it out, but I am not sure I understand what is going. My usecase is also different, so I tried to set it up for what I need instead.
Does this set up make sense at all? This is just an example, but I just want to make shure I am setting it up in the right way.
Thanks
