How to solve "USB device found insufficient permissions" linux
So i have the software installed(running on linux mint) and the axoloti plugged in, but i cannot connect the patcher to the axoloti as i get a message saying "USB device found
insufficient permissions" Im assuming i need to open it with SUDO but i cannot find where the patchers actual launcher software is located to do this :< I have a windows computer i will be able to use later for this(windows vista unfortunetely though) But i'd like to be able to use the patcher on my main comp(the linux mint 10 one im using now)
I have figured it out! Sort of! I went to usr/share/applications then opened axoloti as administrator
no need to use sudo/root .
you can start it from the commandline using
/opt/Axoloti/Axoloti
could be some hotplug issue; try connecting the device before booting.
if that works it could be this:
http://alien.slackbook.org/dokuwiki/doku.php?id=slackware:fixes
Probably udev is not configured to allow user access to the axoloti usb device.
running add_udev_rules.sh in platform_linux should fix this.
