i want my axo to behave like an tc electonics d two, especially the behavior to have an precise control for how many repeats there are... the tc also has a tap rythm wich keeps the latest 8 taps in memory, and grooves the delay then in the ryhtm u tapped.......
How to patch a super delay like tc d two?
Hmm, well multiple delay taps aren't hard to do... Just use multiple reads from the same write. Setting those times arbitrarily from a momentary button will probably be harder. I only just got normal tap delay working.
This is an example of a four tap delay. It can have feedback, but without feedback you get the original sound plus 3 repeats (and then silence). There are individual volume controls for the repeats and a delay time control that scales all the delay times proportionally.
EDIT: Wires in front would probably be more helpful...
