Hey all!
So one thing that put me off from the beginning is the fact, that when using certain objects you could dial in the value with a knob but there is often no modulation input.
I'm coming from max/msp so i'm kinda used to always have a mod input for everything.
I recently learned, that for some objects you can use the "embed as patch/object" command, but that does work only on a few objects. How can I add the missing mod inlets for other objects?
Also, where do I need to save my (or others) patches so that they show up in the search path?
thx for the help!
