how to detect transition from 1 to 0 and 0 to 1?
How to detect transition from 1 to 0 and 0 to 1
logicgate.....i want to write note offs in a table
release velocity is not working with my keyboard , puts out zero always
change?
release velocity is not standardised for keyboard thats cant measure it... i.e. some default it to 0, others 64, some 127
do you know if your keyboard is sending note-off rather than note-on notenum, 0 ?
Id need to check the midi/keyb object but id say release velocity should probably default to 64 BUT if your keyboard is sending note-off then we cannot change that, as note-off 0 is valid.
EDIT: just checked keyb we are defaulting to zero, for note-on notenum/0 we should change this to 64 ... this would help make patches a bit easier to write when using 'legacy midi devices'
that is kind of what I said... its a note on message with the note number and velocity of zero i.e. note-on(notenum,0)
anyway, when I get the chance I will change the release velocity to default to 64 in this scenario....
but its still possible some controllers will send note-off (note#, 0) i.e. they explicitly say the release velocity is zero, and this i don't think we should default to 64... debate
(I will of course double check midi standard to check to see if a release velocity of zero is valid... if its not then I can also default it)
