Hey @Sputnki
I am wondering if you would mind giving another advice on the object?
I am still working on the object and got most of it woriking now. Next thing is to add an invert function. I am having a bit of problems with that. I can patch it with factory objects, buthaving a few issues with coding it. I need to explain a little bit first:
Basicly the object has got 3 functions:
0 = Clean mode:
The input it not converted.
Unipolar input = unipolar output.
Bipolar input = Bipolar output.
Amount knob sets how much of the signal is let through.
1 = Unipolar to bipolar mode:
The input will be converted from unipolar to bipolar.
2 = Bipolar to unipolar mode:
The input will be converted from bipolar to unipolar.
And now I'd like to add an invert function for all 3. The first one "clean" I got working. The second, unipolar to bipolar, I can patch with factory objects like this:
.... Basicly just a 64+ offset, added to the inverted signal. But when I do this in the object, it doesnt give the same result. I know it is wrong, the way I do it, but I just dont understand how to get it right. I added the +64 to TRY to do the same as the picture above
outlet_o= __SMMUL(-inleti+64<<1,param_Am<<4);
But it outputs a pretty random number. I cant really figure out how much it is offset wrongly. Usually you can see it pretty easily, but I cant figure this out.
First I need to get this right and then go on to the final one bipolar to unipolar.
Any suggestion on how I can get it right appreciated
Thanks
