hi i am normaly doing every thing on windows. can anyone help to set this up on mac.
i must have done something wrong. it does not compile the patch. this is the error message with a empty patch:
thanks a lot
thanks a lot
Did you install the Axoloti 'runtime'? ( axo_runtime_mac_1.0.12.dmg )
Note: you don't mention what version of Axoloti you're trying to use - but DO NOT USE 2.0.0. Use Axoloti-1.0.12-2
Note also: the two parts of the install (application and runtime) MUST be the same version.
