Thanks @Johannes, I know there is already work done to go from the stm32f103 to vga, so I don't doubt the Axo can do it. Maybe to go on the list of idea's for archive, I could imagine someone purchasing an Axo in the future, and being able to plug in a monitor to it, even when connected to the gui, you build the patch on a computer etc.. and the Axo outputs relevant data to a monitor. Objects could be designed to select if you want the data displayed etc.. or even different kinds of triggers.. maybe even take some of the processing demand for displaying the data on the gui, like the spectrum analyser, oscilloscopes etc..
It would be great to contribute something, bu this out of my league for now.
I will stick to the Due for now, its more at my level for getting the outcome I desire, plus the additional GPIO's etc..I've decided to drop the Midi side all together, with 16 x momentary foot switches connected to 1 axo analogue, 8 x rotary encoders connected to 16 digital in on axo, so I need 16 digital outs for the led's connected to the momentary's which I will do through the Due. I will use the TX on the Axo to send data from the switches and momentary's to the Due and then play around with displaying it all on a vga monitor. I plan on mounting all this into a aluminium case, the monitor will be in the lid, all the rest goes into the case, but the footswitch panel will be separate from this, because its too big. So there should be plenty of space in the case for extra cables and effects pedals etc..I know all this is a bit off topic, but this is where I am at, just wanted to share the Due to VGA find. I think its cool because it will allow a large volume of info to be displayed, when other display devices are quite small and or costly. For me, the only cost is the Due $20.
