Any plans to make the axoloti able to send midi through the USB port? I'm thinking of developing a way to control my continuum via MIDI and developing using the midi through the USB would be great.. It would also be a nice kickass midi controller w/ the joystick/buttons/etc shield..
Haken continuum interface via USB
It already does send midi thru USB, what do you exactly want that it doesn't do already?
( I think that last part of the quote perhaps is inaccurate / misleading
Can you develop on your idea @bafonso ? Axoloti>Continuum
Its easy to use axoloti+axocontrol along the Haken Continuum
This is from last SuperBooth were I spend all morning having great fun, showing possibilities.
Oh that looks great! My idea was to simply tweak parameters and also have midi LFO for parameters
Ive moved this to a new topic, as the other thread is purely for reporting if controllers work or not, not discussion.
(its already 146 posts, so not good a good place for discussion
honestly, I cant remember, I wrote that when Axo has only just been released (nearly 2 years ago), I suspect its wrong/badly worded - I'll correct it, once ive double checked it with an axo board.
EDIT: ok, tested, as I suspected, its fine - so Ive updated original post.
(re-reading it, I wonder if perhaps its was a limitation in the original firmware, that's now been fixed... anyways works now :))
